Prepare front bottom panel Glue front bottom panel - starbord - assemble wheels Glue front bottom panel - port trim panels and glue in throttle mounting plate Electrical wiring Electrical wiring and circuit design Electrics, paint harness area and baggage hold - paint instrument area rivet tank straps and paint Add foam strip to tank straps Varnish front - 1st coat Varnish front - 2nd coat Varnish front - 3rd coat u'coat cockpit, turtle deck splice and former3/4 side panels - add cloth to cowl surround support Make brackets for tailwheel connections Make turtle deck paint panels and paint instrument panel Install instrument panel avionics Braze pin in tailwheel - painting baggage area - sanding and priming
