Brief Description: Drill and rivet support angles to ribs
Mount each rib and drill through pilot holes, deburr and rivet. Aligned rear spar support onto rib 1, drilled through pilot holes and drilled for AN3 bolt holes through rear spar, reamed for tight fit.
