Sanded off the overhang of wood sheeting from the full length ribs. Set the sanding table down 20 degrees to be able to sand the sheeting without getting in to the cap strip and changing the shape of the ribs.
Set up for sanding down the sheeting without getting the capstrips.
Most people use a router with a 45 degree bit, but I did not have one. Use what you got!
