Started removing wing rib staples. Will finish it back in the states (while watching TV!). Trimmed off excess capstrip from the nose of the ribs. Left them long while building, but the only need to stick out 1 inch to go over the top and bottom of the main spar. Cut them about 1 1/16th and will trim flush on final assembly. Need to finish the spar cutouts on the full ribs that are sheeted. Need to also trim the tailend of the capstrips so they are flush with the tail block. They are close to being done and will get finished and left in the states on this trip home.
Ribs 2 - 10 both wings
Rib #2 has a clipped nose where Rib #10 has a full nose.
Yes, there is one extra #10 rib. Steve Wittman used to give guys a rib to motivate them to build!
