0.6 flight time, 6x around pattern. Used hand-held on the ground, but no headset adapter, so couldn't use in the air. One other plane in the pattern - tracked him visually. Got the headset adapter today, so will try next time. Added an adapter wire from the com radio antenna to the handheld, which seemed to work fine today.
