Sonex 815 Build Logs
Date: 5-5-2009
Number of Hours: 1.00
Brief Description: Flight 48
0.5 flight time, 3x around pattern. Still with the 60 lb weight. Couldn't hear the AWOS, so figured the radio receiver might be out. Uncontrolled field, so decided to go anyway. I had called it on the phone 10 minutes before, so knew they were closing the taxiways at 0630. I got out to the departure end, did the run up, did once around the pattern. Then on the 2nd time around, see 2 other planes taxiing out. Then I see a plane on base in front of me. I guess he slipped in, because I never saw him on downwind. I called position and reported radio receiver out. The two planes took off after my 2nd T&G, and I saw a truck out there closing the taxiways. The guy in front of me was pretty slow, so I figured enough is enough and landed. There was another plane taxiing out. He stopped kind of in the intersection of the taxiways. I needed to get off the runway there, so I called my intentions, and he held position and waved as I went by, so I think the transmitter is working.
