Soldered on longer leads for the PTT onto the mic jack. Will need to run these across behind the panel from the jack to the right side, over the spar box then join them into the PTT wires that go to the switch on the stick. Also removed the LH cowl and tried to get the oil filter spacer ring off. I bought a replacement fitting for the one that leaks. If that doesn't work, I'll have to buy a new spacer ring and start over (bought 2 more fittings for that possible job).
