Brought the needed screwdriver for the EIS connections. Unscrewed the encoder, pressed the static line onto it. Screwed on the EIS connections. Installed the fasteners around the perimeter of the panel. Powered it on and checked the EIS. Looks good, but I will need to set the limits. Ran the mixture cable through the firewall down to the Aerocarb. Brought a lot of stuff, but didn't bring the allen wrench needed to tighten this up. Also will need to add some clamps to the mixture and throttle cables to keep them off the engine mount.
Panel w/ all the stuff. Wires & hoses on right side not finalized.
