Worked on the switch plate brackets. Got these trimmed to fit below the upper avionics support angle top bolts, and drilled them to these angles. Put the switch plate in place over the brackets and drilled through the nutplate locations. Removed the brackets, clecoed the nutplates to the screw holes. Realized one nutplate is too close to the top of one of the brackets.
