Completed the RH air vent tube installation, with a piece of screen at the outboard end to prevent unexpected insects from blasting through the vent in flight. Completed the fuel sight tube installation, except for adding a support at the upper end - plan to use a self-adhesive tie wrap base to the underside of the glare shield, then just tie wrap the tube up to it.
