With the order for the antenna, threw in some more nutplates to finish the one on the brake backing plate for the wheel pant. Jacked up the left side with the sawhorse under the wing, removed the wheel and installed the nutplate. Sawhorse is low enough that under the wing doesn't get the wheel high enough to remove from the axle, but was high enough to slide it down the axle far enough to get the nutplate in there. Remembered that when I did this before I put the saw horse under the fuselage and weighted the tail down - that would give the extra 2-3" to get the wheels off.
