Formed up the left gear leg fairing. Cut down the hinges due to the fairing being 1" shorter than print. Formed it around the gear leg. Seems to fit better at the top than the right one and may need a little more trimming at the bottom. I can see how these help - the actual gear leg is maybe 1/3 of the way back in the fairing, so the wind sees a tighter leading edge as well as trailing edge.
It's not easy to get the hinge pins in, but they will go.
