Spent about half the time disassembling the rudder pedals from the fuselage. Took the mount blocks off and blended a little more chamfer onto the edge nearest the weld. Put the blocks back in and the pedals move more freely. Filed inside the lower motor mount tubes to allow the gear legs to insert easily. Ran 1/4" drill through the gear leg retention bolt holes to allow the bolts to be inserted. Initially tried filing, but that was not working, even after filing on one tube for quite a while. Didn't really want to run a drill through because the tubes should have been large enough. But the bolts insert nicely now.
