I will have one 2 1/4 and one 3 1/8 instrument holes blanked off in the panel initially. The 2 1/4 is on the RH panel - a good spot for a g-meter. The 3 1/8 is where the GPS will be sitting. If the GPS is ever removed/replaced, the idea would be to move the airspeed up to where the blank is, and possibly add a turn rate gyro or maybe vertical card compass where the airspeed is going to start out on the bottom row. Made the blanks from .032. Cleaned, primed, and painted flat black.
