Laid out a few details for the canopy installation - the pilot's side outer cover strip, and the 2 little clips for the handle return spring. Also drilled and riveted the lock plate (to be used to lock the canopy closed). Considering using Sikaflex to fasten the canopy with adhesive - need to work out details on the bottom edge of each side to accomplish this. Went back out after a while and laid out the side trim part, cut and drilled it. Then made another side trim for the right side. Not sure if I'll use this, but there it is. Also made the guide pin.
