Sonex 815 Build Logs
Date: 8-11-2007
Number of Hours: 3.50
Manual Reference: D01
Brief Description: Windshield installation
Got the replacement polycarbonate earlier in the week. Made the initial cuts in about 1/2 hour after using the first windshield as a template - but extended the sides down farther. About 3/16" at the forward end, about 1 1/2" at the aft end. Spent the next 3 hours fitting the windshield to the fuselage, marking for trim, removing, trimming, etc. Took the sides down in 1/16" - 1/8" increments until it fit nice. Fabricated the .025 strip that goes along the windshield bow that adjoins the canopy. Got it fit into place and decided to make a tool to get the holes through it, the windshield bow and the windshield all lined up. Took a few minutes to make up the tool out of some scraps. Still need to drill these holes along the windshield bow, remove the windshield, countersink the holes there at 5/32, drill those holes up to 11/64, and paint the rivets on the glare shield which have not yet been painted. Also paint the trim strip and windshield bow then install all the screws.
Clamped in place with trim strip.
Clamped in place.
Drilled left side.
