Drilled bottom skin to the two sides. Removed firewall and drilled the central support square tube to the firewall on the floor, with the tube clamped to the firewall at both ends. This is much easier than trying to drill the square tube with the firewall in place. Put the firewall back in position and drilled it to the underlying attach points on the top and two sides.
