Finally back to F12. Drilled all the angle stock parts to the skin. Upper and lower longerons, then the vertical angles, front to back as called out on the print, plus the seatbelt attach angle and gear mount angle. Started to position the motor mount brackets and left it at that. This was early in the morning before setting out to Henderson / Las Vegas to pick up a cowling and engine mount.
