Fabricated the .032 details on F14. These include the firewall attach angle (had to check the remaining piece of the Zxx-xx stock I ordered from Sonex - there was just enough to make this and leave the 1 piece left over for another ~35" long detail in the aft spar pass-through area), and the upper and lower firewall attach angles at the motor mount brackets. Also fabricated the cowl attach hinge and the F14-01 assembly (cowl attach hinge plus firewall attach angle drilled to the 1/8" thick forward angle).
