Finished the cutting and shaping of the F14 details with the sanding drum on the Dremel, and also used the cutting "drum" on the Dremel. Had to use these to get the inside corners radiused and smoothed. Finished off with the scotch brite wheel. Also drilled the angle stock parts. Finished all but the two 1.5" angle stock parts that need to have the angles adjusted. I think this time I'm finally going to mount the vise on one of the work benches so I can get more leverage on it. To this point it's just been sitting on the floor, and though it weighs 50 pounds or more, it will still move around far too much to really crush the parts to a different angle. (Works ok for short stuff like the 2" long angles on the H-stab forward spar, but the long ones on F14 don't change angle.)
