Remade F20-09R because I had the bend radius too far up the part. I had bent this prior to making the bending tool, so I got a bit tighter radius as well. Installed the F20-09R and finished pilot drilling the one on the left side as well. Installed the center splice plate and the forward clip that is behind it. Installed the left side #4 former. The formers require a lot of tweaking, and even so, I think I will need to make some spacers to avoid dimples on the outer skin. The #4 former is probably the most difficult to drill since part of it is done from inside the aft bay (the smallest one).
Lower and center splice plates in position.
Outside showing LHS #4 former location.
Inside view. The one on the right (the LHS former) is all pilot drilled.
