Remade F22-06 because I found it was drilled too low (not tight to the upper shear web). This took about 1/2 hour. The remaining time was setting up to drill it to the shear web.
Remade this angle 3x due to drilling errors. Clamp it up tight to the longerons with .025 spacer.
