Cut slots in upper cockpit angle for canopy latch. First slot - drilled row of holes and connected between holes with dremel shaping bit, finished with file. Second slot - drilled row of holes and connected with cut-off wheel in dremel. Cut off wheel worked a lot better - gives a straight cut.
