Took about 1/2 hr to complete the rivets in the RH spar. Took about 1/2 hr to work the fixes - had 4 rivets to drill out and re set. Took about 1/2 hr to check the spar-to-spar fit - looks good. (Already did the ream to 1/4" before riveting.) Other than bolting on the root rib angles to the RH spar, W08 is DONE! To those who haven't been there, I think it's the hardest sheet to complete yet, and having completed it, I know I can crank out the rest of this thing. I would not recommend starting with the spar or wing. Carve up a bunch of angle stock first, at least.
