Deburring was done. Cleaned the spar webs with alcohol, acetone, alcohol again. Ran scotch brite over the surface, and cleaned off that dust with alcohol twice. Sprayed a light coat of zinc chromate primer on the web inside surfaces of the spar. I know it is said that the airplane needs nothing, but I did these few areas of these few parts just because.
