Sonex 815 Build Logs
Sonex
Remove oil cooler
Disassembled the oil cooler from the baffle. Set the hoses on the engine so they wouldn't continue to drain. Took the oil cooler home and removed the fittings. Packed it up for return.
Aft side. Oil all down right side.
Forwards side. Trimmed bottom for baffle.
Sonex Home
1491
Cowling
142
107
Flights
111
141
441
43
Panel
361
