Sonex 815 Build Logs
Sonex
Remove oil cooler
Removed the oil cooler. Set it over a collection pan to drain. Noted soot on the left side of the oil cooler baffle - means engine is running rich. Not sure if that's just on the ground or in flight as well.
Soot on baffle. AC fwd is up in this view.
Area where the soot was found.
Sonex Home
1491
Cowling
142
107
Flights
111
141
441
43
Panel
361
