Swapped out the air filter for a larger one. This one has plenty of area (K&N RU 3560), but it contacts the engine mount tubes. May need to add an angle adapter here. Also adjusted the idle speed down, rolled it out, and started it up. Good, right around 1000 rpm. Met Jim Arbore out at the plane this morning. He's building a Xenos and seems to be pretty far along.
