Put tie wraps on both ends of the sight tube at the tank fittings so the tube won't pull off. Put the fuel back in the tank that I had in plastic containers (about 8 gal.). No leaks, good. Reworked the ground wire to the transponder which had pulled out of the connector when I disassembled the panel. Replaced most of the fasteners along the bottom sides of the windshield as they were too short. Will need help getting the forwards 2 or 3 on each side. Checked the tube of adhesive for the canopy trims - all dried up. Will either need to order another or use something else such as the silicone that I used to seal up the firewall.
