Sonex 815 Build Logs
Date: 8-29-2008
Number of Hours: 2.50
Brief Description: Reinstall tank
Got both straps secured, the tube from the tank valve to firewall back in. Got the ground wires hooked back up to the grounding block, and the few switch panel wires that were removed are reinstalled. Got the left side of the panel back in place - air vent hose, mixture cable, the panel itself, and the ball hung off the bottom of the panel. Got the switch panel back in place. Got the right panel back in place - fuel sight tube, air vent tube. Need to put zip ties on the sight tube at the fuel tank fittings so that hose can't pull back off. Got the tank aft angles riveted back on. Bolted the sticks back on. Got the drip pan and vent tube reinstalled at the fill neck. Got the mixture cable reattached to the carb. Need to replace a few tie wraps that up there that secured the mixture cable. Forgot what a tough thing it is to get the tank straps tight. Didn't fill it or check for leaks. After this, I forsee ELT batteries, glue the canopy side trim (forward and aft ends are a little loose), set up for a hand-held radio, and safety wire the gascolator bowl.
