Brief Description: Various fwf wiring, switch panel
Byron stopped by to help me tighten a few through-firewall fasteners for the regulator relay. He also pointed out that the CHT and EGT would need acid flux to solder, not the usual electronics rosin core solder. Good point - I tried soldering them and the solder doesn't stick or flow at all. But the acid flux residue has to be cleaned off after soldering. Also worked on the switch panel. I drilled pilot holes in the .025 mock up switch panel and found a few that needed to be relocated. Now I can make the whole thing over again in .062.
