Made up the various wires for the voltage regulator and its relay. Also made up the wires for the oil pressure and oil temperature sensors. The oil temperature has an odd-looking round end on it, but a standard 1/4" faston will slide over it. The CHT's and EGT's need to be extended to reach the instrument wiring. Wasn't too thrilled about trying to solder on these extensions while working below the glare shield. Came up with what may be a good idea - solder on extensions while the wires are hanging out forwards of the firewall, then push them through with the extensions already in place.
