Sonex 815 Build Logs
Sonex
Oil cooler baffle
Reworked the oil cooler baffle to put the quick drain inside the air flow path. This seems to be much simpler to make fit. By the time it was done, it was a 6-piece assembly. So many clecoes holding it together, it can't be tried in place for fit.
This will fit better.
Sonex Home
1491
Cowling
142
107
Flights
111
141
441
43
Panel
361
