Reworked the oil cooler hanger bracket to raise the cooler up. Had to detach and re-attach the bracket on this bracket that holds the clamp for the hose loop. Installed the oil quick drain. Started working on a box around the quick drain. Box is needed because the quick drain will not fit inside the baffle as it was. This first box excludes the quick drain from the flow path. I may try again with a box which includes the quick drain in the flow path, as this first box seems to be getting pretty complicated, and it still doesn't work.
