Worked on the 2 bearing/bushings that mount the sticks assembly to the fuselage. Found that the oilite bushings are too short - the idea is to pinch the bushing on the bolt so the bolt and bushing do not rotate, and only the steel sticks assembly rotates. The bushings are line-on-line with the thickness of the steel - not counting leaving any powder coat on the steel. So I'll have to order -4 length bushings. Also made a 1/8" and 3/16" thick spacers for either side (could just use washers).
