Started the control sticks assembly. Needed to take the powder coat off the lower stick part to get it through the bushings in the control triangle. Used sandpaper wrapped around this and it took quite a while. Also used sandpaper and emery cloth wrapped around a drill extension in the drill to ream out the bushings.
