Drilled the adjuster, trimmed the end. Reinstalled the adjuster on the pedal, installed the cable on the adjuster. Then took most of the time to tighten the pedal blocks back. The left pedal seems to go a little closer to the firewall at full travel, so I might make another adjuster and drill the cable hole further up so the adjuster is a little shorter. (Don't need to remove the pedal blocks to get the left adjuster off.) But they seem to be centered pretty well. Kind of a weird feel to the pedals. I know it's my big shoes with the funny tread, but I might have to get some slippers or socks to fly this thing, and I'm pretty sure I want to put some of that skateboard grip surface on the floor where your heels go. Took a few minutes to put the panel lower cross brace in place. Didn't tighten any fasteners there though, just got it off the table.
