Sonex 815 Build Logs
Sonex
H-stab details
H-stab ribs - deburred the long edges, pulled off the white plastic backing, started to mark a few for cutting. Made the hinge pin for the trim tab. Found the elevator skins, marked these for cutting.
Using brake to bend rib end flange.
Checking bend angle with template.
Sonex Home
1491
Cowling
142
107
Flights
111
141
441
43
Panel
361
