Cut the scarfs on the bottom fuselage sheeting. Double checked to make sure the fuse was not twisted and generally in the right position. Applied sheeting with T-88. Notice that I haven't yet installed the gussets on the bottom or top cross-members yet. The fuse did have a slight twist, so I wanted to get that "locked out" before it was permanent with the application of the bottom sheeting. Next step is to install all the gussets.
