Spent the night working on the upper fuselage sides (per D-33). Made the template for checking, then decided to make a larger one that I could sand with. Just cut it out of a 2x4. I used the sureform to get it down close to contour, and then sanded with the shaped block. PVC foam is miserable to sand, but this seemed to work ok - and I'm getting a workout in the process!
