Located the position of the rear ribs (7A1-3), drilled & clecoed in place. All holes were drilled with #40 pilot holes, will updrill later. Positioned nose ribs (7A1-2), drilled & clecoed, then, drilled nose ribs to hinge brackets (A5 rivets). Clecoed the components together.
