Laid out & cut the 26 mm angle on all of the flaperon hinge brackets (7A1-5). Also, laid out & drilled the 2-mounting holes. Drilled & clecoed the 2-hinge brackets to the spar (7A1-4) # 40 bit. Also, laid out position of rear ribs on spar & skin (7A2-1).
