Installed fuel tank in it's final place, by screwing "U" channels on Rib #2 in place with nutplates (8/32). Screwed finger screen into tank (ZAC P/N DX2021) & nipple fitting (ZAC P/N F125-4B) coated threads with Fuel Lube. Ran the tank sender ground wire (white) & red center stud sender wire through a lightning hole in rib # 1 & through an adhesive tie rap mount riveted to rib. I used ring tongue terminals on these wires, size 6-stud hole (P/N 31885). the sender ground wire got riveted to rib # 1 (A-4).
