Laid out & drilled a 7/8" hole in Rib # 1 for the fuel outlet hose & another 7/8" hole in bottom skin for fuel drain using a unibit drill bit. Rivited ground wire to tab on fuel tank using a ring tongue terminal (P/N 31885) & A-4 rivet ( white wire). Hooked up ground wire on sender with a ring terminal ( white wire). Used spiral plastic tubing to protect wires, also, used 2- adhesive cable tie mounts on top of tank to hold wires in place. Cut hole in top skin for tank opening with snips & filed all edges & rounded inside corners.
