Brief Description: Front Strut Fitting, Spar Doubler
Bolted strut fitting to spar. Note: Strut fitting should have been put on before lower skins were riveted. Could not get lower bolt (upside down one) between skin and flange. Had to remove 4-rivets along spar cap to squeeze bolt in place. Re-riveted. Laid out rivet pattern for spar doubler, to be drilled later when skins are riveted. Note: The spar doubler should have been drilled earlier when spar cap was drilled, now extra work & time.
