Ran 1/4"x20 threaded rod through 1/4" machining holes in nose ribs & clamped a 4x4 block of wood to threaded to hold everything in place. This will achieve proper spacing and hold nose ribs square to spar while drilling nose skin. Rod will be removed after nose skin is drilled.
