Brief Description: Continued lay up of rudder spar, ribs and lower sk
Determined location for aft position light mount on rudder. layed out cable route from light thru rudder, thru F-12 to cable connections in aft tail area. Drilled cable feedthru in center rudder rib and rudder spar and added grommets. Ran new #18 wire from cockpit area aft along stbd side to tail section and added snap connector at termination. attached #18 ground wire in aft tail section with snap connector as well.
Positioned lower rudder rib, doubler and spar and riveted all three pieces together. Located yoke at bottom front of rudder. Drilled thru yoke, bottom rib and doubled and bolted yoke in place.
aft pos. light cable feedthru in rudder middle rib
