Countersank top rivet joint on spar. Deburred spar angles and web, clecoed and flush riveted. Drilled lower fin hinge 5/16" for bushing. Cut and shaped fin upper hinge bracket. Located and drilled 5/16" hole for bushing. Verified fit of upper fin rib into spar.
