Brief Description: completed riveting cntr ribs and cut cntr temporar
completed riveting ribs to rear spar and cut and drilled tempory cntr floor to hold cntr wing square. riveted floor in place and unbolted wings for cntr wing. I need .032" aluminum for the cntr floor and bottom skin. I will order that and install it next rotation home. I also temporarily riveted in the 3/4" aluminum angle at the fwd end of the floor plate. I will remove, drill and tap this angle when I change the floor material.
