Brief Description: fabbed rudder hinges and ift to rudder and fin spa
Fabricated rudder hinge blanks and shaped to existing fin hinge blanks. assembled hinges with bushings and located mounting bolt locations. Added trap nuts to rudder hinge mounts so that rudder can be bolted to fin with hinges assembled together and in place. Hinge bushings will be trimmed flush and flat washers used during assembly.Will add F5000-3 trap nuts to upper hinge only on the fin spar as well
